modded psu question
wayne
how do i test my stripped down psu to check if it works or not?
i had a mod where i needed to strip the psu casing to save space but my harddrive died and i wanna test if the psu still works fine.... im 99% sure it still does but is there some sorta procedure i must do to check if it works
so far, i plugged it in and fan spins and it looks fine but i dont know about the voltage stability or whatever
this is a generic psu but i had used it before i stripped it down and i know its a good psu... with some sorta quality
help... i need to finish my mod and i need to know asap
thanks
If you had a multimeter you could use that to check voltages and such....but if It was me, I would just grab another HD plug it in and see if it goes...
see if it goes what??? :eek:
i have a multimeter... but is this a good way to test if it works good?... the only way im used to is plugging in the system and check but this ones a special mod i did and i dont think i can get another one of this motherboard so i rather not screw it up... its also kinda hard to take it out because i ran the wiring thru a lotta stuff
is there a standard way to check/test a psu to see if it works well?, or should i just use the multimeter thing?, or should i really take it out and try it on a crap system?
btw, my multimeter is the needle kinds with scales, not digital so it would be kinda hard to get accurate voltages
help!!!!.. thanks :)
I forget which pins, but you can short two of them on the atx connector to
get the PSU to fire up. Then test with a multimeter.
You may want to put some load onto it, as they don't like running without
out any. the up/downside of switching mode psu's.
I saw an article about converting an atx psu to a benchtop powersupply for electronics.
if you can find it, it had some good info, including ways to keep it from blowing up, and over heating.
good luck
-Jeff.
Imo easiest thing to do is throw it in a crap system.
You can power up an atx psu by grounding pin 14 (typically green wire), but most units require about a 10% load in order to be stable. As you probably lack the high wattage resisters to provide this load, you'll have to run some drives or other components anyway.
good luck
-Jeff.
The green wire (pin 14) to any ground (black) wire.
Yes, you need to put a load on the PSU.
yea, i know, green wire and any black... thats how i turned it on
so i think im going to try the multimeter thing but its gonna be hard to tell because mine isnt digital, its the scaled kinds with a needle
then i ll probably try a crap system then
