Modded G5 - Pictures!
RabidRat
I was inspired by the R.A.T. mouse: conventional ergonomics be damned, a mouse will be just as comfortable when the points of contact are only at specific points anyway.
It fits so much better in my hand now. No more stupid thumb and pinky grips; my fingers can finally go where they want and I get the control I always felt was being robbed of me.
The thing is way lighter now too. The shell is like a brick.
Taking suggestions on what else to do to it!! =D
It only had a back button, and yup I can press it. It's just more recessed now so it's not as comfortable to hit.
Correct me if I'm wrong, but if you accumulate enough static electricity and accidentally graze some of the components inside the G5, isn't there a risk you'll b0rk it? ...
Nope. There is an IC in there (just one, DIP), but it's deep in the middle of the mouse buried behind a mess of mechanical switches; there's absolutely no risk of that happening.
Update: someone local is offering to donate their old G7 for parts!! It has an issue with the left mouse click, but the rest of it's fine. I'm gonna see if I can rip out the rechargeable battery pack system and the wireless transceiver and transplant it into the G5.
I'm a little concerned that I may need to modify the drivers, which might be downright impossible because I don't think they're open source. I'll have to see how it works.
