Modded Duron Temps
Seongmin
Hey, I have a 1.8 Duron that is modded to an XP2200, which is overclocked to 2.2ghz (200 x 11) ;) . I know that this isn't much of a cpu, but I am trying to squeeze everything out of it that I possibly can before upgrading. Well, the dilemma here is that my temps are in the upper 50's... Is this normal for a Duron? Also, when I try running the cpu at (200 x 11.5) 2.3ghz, the computer restarts during the day but is stable during the night, meaning the cooling isn't adequate correct? Enlighten me please! :D
thats good for a duron i beleive. 50 degree range isnt gonna hurt you at all. People are usually just anal about temps.
if it crashes when you arent using it, basically just means that its stable when its not doing anything, which doesnt mean much :p
50C is ok, but not great. my XP runs at 2.5ghz with 1.85v all day under 45C, zalman cnps7000cu
