Mod My Koolance Case?
badwished
I have the new Koolance PC4-1026BK with the new Koolance 330 Block, and the 8800GTX Block, Cooling a Qx6700 My question is if I remove the pump from the drive bay and move it to the bottom of the case and install Custom Delrin DDC Pump Top for MCP350/355 . Wil this make much difference in cooling?
I doubt putting a top on the pump will do much since your loop doesn't appear to be that restrictive. However better blocks and a rad would most likely make a difference.
Wow you alread spend big money why you want to spend your. What are you temperatures?
