"One Off" exclusive build, The Mod Men ITX HTPC designed by Cheapskate, built by Mnpctech
SYSTEM SPECS:
Motherboard = ZOTAC H55 ITX 1156
CPU = Intel Core i7-870 Lynnfield 2.93GHz 8MB L3 Cache LGA 1156 95W Quad-Core
GPU = ZOTAC 470 GTX
SSD: Mushkin Callisto 64GB
PSU: Silverstone 600W
COOLING SPECS:
CPU = Custom Copper water block (designed by cheapskate, randy's swirl design)
(Acrylic water block tops fabricated and designed by cheapskate)
GPU Cooling = EK-FC470 GTX water block (would have made our own, if time allowed)
Radiator: Hardware Labs 360 GT Stealth
Reservoir = Custom made with manual pressure regulator! (designed & fabricated by cheapskate)
Pump = MCP350
Tygon 3603 3/8" ID (1/2" OD) Clear Tubing
EK PSC fittings, except for water block top (EK hi-flo)
CONSTRUCTION:
Tower: 2" thick cast clear acrylic (cnc milled)
Tower Sides: 1/8" thick Blue & UV Green transparent cast acrylic (cnc milled)
Base for PSU: 2" thick cast clear acrylic (cnc milled)
Optical drive shell: 2" thick cast clear acrylic (cnc milled)
Optical drive cover" 3/16" thick billet aluminum with fins
Front Plates: 1/4" thick Blue transparent cast acrylic and 3/16" thick billet (cnc milled)
Rear PSU Mounting: 1" billet aluminum
MB stand-offs: billet aluminum
Power switch: 22mm Bulgin Blue Ring Momentary
SYSTEM SPECS:
GPU = ZOTAC 470 GTX
COOLING SPECS:
Pump = MCP350
CONSTRUCTION:
