Mod help, noob
apex32
I have an aspire X-Dreamer 2 (black) and a Thermaltake Xaser 3 (silver). Is ther any moding i can do on these? they look a little plain. I bought uv paint, and had my friend draw something on cardboard since hes very talented and use it as a stencil. But thats not much of a case mod, now is it.
maybe cut a window? mount fans? watercooling? :confused:
depends on your budget
yeah i was thinking about watercooling. but what ones are good for around 200 or less. i dont want to spend a lot. and im scared to cut a window lol. im afraid ill make it all bad
Try it on a crappy case first so you get the idea. its not hard at all, just be patience. you can get kits from frozencpu for pretty cheap, comes with the molding and everything.
As for the water cooling set up there are a million options you can go with, just depends on how custom you want it. There are also kits put together that you just slap on. Try searching aroudn frozencpu.com for a bit and you can get the idea.
thtas cool. i just dont know what companies are better than others. And what do you use to cut the window? just like a jig saw then sand it down and but in the plexiglass with the molding. both cases have 1 side window. i rwally want to cut a window on the top!
what? why. lol i have never done a case mod before. hence im a noob. why does it matter to you?
