Mochibot Has 32 Legs
AlphaAtlas
Giant hexapods may be impressive, but Japanese researchers are looking to one up that. "Mochibot" has they call it, uses 32 extendable legs to roll around on surfaces. Advanced software is used to plot the path of the contraption.
Check out a video of the robot here.
Mochibot's big advantage over a tensegrity robot is that it can move smoothly and continuously in any direction you like by altering its shape. This gives it an advantage over wheeled exploration robots as well, since all directions can be optimal for movement, rather than just forward and backward. The designers also suggest that Mochibot is better at dealing with deformable terrain like sand or loose rock, because its method of rolling locomotion is much less traction dependent. And if something does go wrong with one of the legs, well, you've got 31 others backing you up, so no big deal. For applications like planetary exploration or disaster response, Mochibot has the potential to be a versatile platform. It's highly mobile, very redundant, and looks like it could manage a hefty science payload. The next step is to experiment with different kinds of terrain, making sure that Mochibot can roll itself up and down slopes and over rocks and gullies without any problems.
Was hoping for a rabid AI centipede, but instead saw a rolling pile of granny's knitting needles. Will the 'hefty science payload' be a nice cardigan?
I want a car like this... think of the crash protection potential...
Also think of the outcome when the auto leveling fails in your cockpit. then you will swim out of it on a sea of vomit
Haha that alone should be reason enough to do it... imagine the news reports.
Anyway, sea of vomit > dead :)
