Mobo wont stay powered.... Please help.
Isurus
Okay, i have to be honest... its been a long time since ive done any major Comp repair to my system... So to make a short story even shorter....
I replaced my Mobo...
when i went to power it up Nothing happened. (Hit the powerswitch on the Case)
So figuring i turned off the powersupply i turned it what i thought was off... all of the fans turned on, and went RIGHT off.... The Button on the case still does Nothing...
Its pluged in correctly - Via the instructions that came with the Mobo.
However, when i turn the Power Supply off and back on, the fans will come on again, and then go right off..... its as if the PC doesnt want to stay running. ive tryed 2 Power supplys, same result with both. ive also unpluged everything to see if it would at least load into Bio's and it wont even stay on long enough.
Please Help.
The New Mobo is an AMD 939 - S1 689 uli m1689
made by Chaintech
sometimes you have to plug in the 4 pin AND the 20/24 pin connector to get mobos to power up. if not, check to make sure you are running the correct voltage in the back of your PSU. the worst that can happen is that both your mobo and PSU are bad, its never happened in my lifetime building comps but theres a first time for everything...
Thanks for the Reply.
I have both the Power Connections connected to the Mobo... and the Power Supply is running 115v...
I Just got the Mobo and Processor today... i Hope that they arnt bad. even though i have the warranty... i just want to get the PC up and running.
I press power, and the computer will turn on, but then after about 1 or 2 seconds, it turns back off. Once this happens, it doesn't respond to any further pushing of the power button unless I hold down the power button (as if manually shutting it down), or flip the switch on the back. Interestingly, once I flip the switch (I/O) back into the "on" position, the lights and fans on my computer will turn on for a split second (much shorter than when I actually press the power button), then turn on, almost as if the computer is trying to turn on, then stops itself for whatever reason.
I am thinking that it must be a voltage issue, however it seems odd since I am obviously posting this on a different computer which is in the same room. Anyone have any ideas of what to do, or is something fried that I will have to replace?
i found this at: http://www.softwaretipsandtricks.com/forum/showthread.php?t=23458&goto=nextnewest
its the same thing as what mine is doing... Might be the PSU?
I think the initial 1-2sec fan activation is an initial self-test by the computer. I have seen many computers (specially AMD's) doing this before the power swith is turned on. It is normal. You have something else going on here. Do you have the right RAM correctly installed? It helps if you can give full system specs.
Its been a while... but here it goes.
1gig Pc3200 ram (2x512)
AMD Athlon64 3500
Chaintech Mobo Socket 939 - S1689 - Uli M1689 Chipset
Raedon 9600XT 256meg
200gig Maxtor HD
550w PSU
Hope that Helps.
Tried One Chip... Nothing. If thats the Inital Test. What do you think it could be?
Thanks for your Help.
Still Nothing....
Dont know what to do now... Anyone else have anything i should try?
PC Still Shuts down after 1 - 2 seconds. Vsrdan he thinks that the 1-2 second activation of Fan and lights could be an Inital test...
Any More help would be Awesome. Please.
Some more things to try...
(1) Try a different video card
(2) Try a different PSU
(3) Take out CPU and see if all the pins are "intact"
Something should work. If nothing works, it is safe to say it is the motherboard.
Also make sure you didn't ground the mobo out when you mounted it.
Check to make sure all cards are seated firmly.
Make sure no IDE straps could be backward.
could be your outlet. try plugging in your system in a different outlet in your house...
that happened to me once...check the power button on the case and make sure it is still sodered on there well...cause when I build my computer my friend took off the front to install some fans and semi-disconnected the power switch so it would light up and all the fans would spin but then it would shut right off...his brother resodered the power switch for me and its been fine for about a year now
This happened to a friend of mine also. The heatsink was not mounted correctly on the CPU (backwards - it was an AthlonXP) and it was overheating and the board's safety feature was shutting it off after about 2 seconds on.
With the heatspreader I don't know if an Athlon64 would overheat that fast or not, but it's worth a look, just remove the heatsink and see if your goo has been mushed around a bit. I don't really even know if you can mount Athlon64 heatsinks backwards or not, I know the XP-120 can go on either way, but not sure on stock.
Im gonna say its your vid card.. this just happened to me a few days ago... i was nunning 2 6600gt (bfg) and one died.. system would turn on for 1-2 secs, then stop and not respond to other boot attempts... after a lot of testing it turned out to be one of my brand new vid cards :(
remove all your components and plug in the most basic psu rails (20/24 pin, and 4 pin if necessary) then continue to add video card, harddrives, soundcard, etc. until it starts shuttin off. also, if your board is shorted out on the case (can be caused by the screws holding the board connecting a circuit and grounding it) then remove some screws and add the most basic ones that will keep the board in the case safely.
this is what i always do when i have problems. tends to show whats goin wrong. ;)
I could be the cpu. If it is not seated correctly and is getting too hot too fast. Try uninstalling it and putting another round of TIM on there.
try booting only the CPU and board and ram. nothing else. see if it stays on. if it does, add stuff part by part until it starts screwing up again. do this outside of the case, so you know nothing is being shorted.
