Mobo won't display - Help!
Gen.Viper
Man, been having this problem since just after the [H] went down, and I can't figure out what it is. Basically, I turn on my computer, but nothign displys: no BIOS, no bootup, nothing. The thing beeps, the processor starts up, and the mobo LED turns on, but nothing displays. I tried switching AGP cards, didn't work; tried two different PCI cards, didn't work; tried the monitor out on my main comp: it works fine; tried switching processors, didn't work. So I turn now to you all, the [H]ardest of the hard, for help. Any idea if its something I can fix? Or must I turn to a new mobo? Graci!
BTW, the mobo is an ASUS P3B-F Slot 1
the processor is a PIII 833 Mhz
Strip it down to the bare minimum: Processor, one stick of RAM, and video card. nothing else plugged in, not even hard drives. (a backwards IDE cable will do exactly what you describe, but so will several other things)
Then if you get a BIOS screen, start replacing parts one at a time till you find the culpret.
If you do not get a BIOS screen, what is the beep code?
==>Lazn
I've got the same problem.
It worked perfectly fine for a year and a half, since I put it together. Firstly my monitor has a blurry section in the middle. Then it showed fine whisker lines, like static, in the center all the way across. Then it would go clear.
Yesterday I was using it (screen was clear) and surfing the web, as you do, and it just locked up. wtf? I thought. Pressed Reset and away everything went as usual.
80% loaded Windows, it locks up again. wtf? again! Pressed Reset and it goes black. Doesn't do anything. Doesn't load, no beeps, nothing on the screen, HDD and power lights are on, mobo light on, all fans are spinning.
Turn it off, check everything inside. Clean the vid card (which was dusty), the fan spins real smooth now.
Everything looks normal.
Next, I start it up again. Again, nothing. This time the monitor shows "No Signal".
Put a different monitor on my pc, same thing "No Signal".
So I take my vid card to a pc shop, they test it and it works perfectly. They said "Possibly it's your mainboard." Ya great.
Whats wrong with it? battery? something bad? If it is, is it possible to get it repaired? Or should I just get a new mobo?
P.S. I'm very poor, so the cheaper the better.
P.P.S. Sorry for highjacking your thread! But the problem seems exactly the same.
Specs:
WinXP Pro
ASUS A7V8X
AMD XP2000 CPU
Albatron GeForce 4 MX440, 64MB DDR w/TV Out (AGP)
one Kingston 512mb DDR RAM
Leadtek Winfast TV Card
Seagate 80g HDD
Maxtor 80g HDD
Liteon CDRW 48x12x48
Liteon CD-ROM 52x
Both sound like PSU issues.
I'm betting you need a new PSU. If it starts losing the ability to deliver a clean voltage or deliver the proper amount of amps, all kinds of "untraceable" wierdness happens.
BB
Ja, update on my problem.
The pc actually turned on today. Smelt some God aweful stench coming from the monitor, so for some strange reason, I set it to 60mhz (from 85mhz). Everything is working perfectly.......... :confused:
can anyone explain?
P.S. I hate the flickering of 60mhz. That's why I had it on 85mhz (for a year with no problems).
