mobo wont detect raid set except...
Xenozx
ok i have run into a little problem. I have 2 IDE drives and 2 sata drives. The 2 sata drives are in a RAID 0 config. anyway when i boot up and i DONT have the 2 IDE drives plugged in i can go into the bios and it detects my raid set and lets me set it as a boot device. if i shut down from there and plug the 2 IDE drives in and power back up and enter the bios it now doesnt show the raid 0 config as a bootable option but then allows me to select the 2 ide drives to boot from. i dont want to boot from the 2 ide i want to boot from the raid set. but now it seems that the only way this can happen is by not connecting my 2 ide drives. the only problem is that is where all my movies/mp3's are saved and i want access to them.
I did try this to no avail.
I had connected all my drives. i then turned my machine on and booted from my windows xp cd. i then installed my third party raid drivers. after that i installed windows on my raid config just on a different partition. once the windows install completed i went into my bios and still did not have the option to boot from the raid device. i dont know what happend. any idea's?
i have a asus a8v deluxe mobo. im using the VIA raid controller.
