MoBo with faulty audio ?
hiteak86
I just recently updated my OS from XP home to Pro, and I realized after installing all of the drivers, that I have no sound. In the "Sounds, Speech, and Audio" control panel, it has all of the options for controlling my system audios volume greyd out.
Device manager even claims that there is no audio device, which is odd because there is an audo output on the MoBo that I just bought, and could have swore that the audio worked when I had XP Home.
Any ideas as to what the problem is ?
Thanks,
-Vito
Right click on My computer, and go to properties, then go to hardware, then device manager. Is there any lines of text with a ! next to it. Because if your audio worked before then drivers are to blame. Try going to the manufactures website of your motherboard and download the drivers off their site.
Nope, nothing with exclamation marks next to it in device manager. This is just too strange.
I had a similar problem with an ECS NForce3 motherboard. I couldn't get the onboard audio to show up in WinXP so I ended up installing an extra audio card. Once I did that, both the onboard and the extra audio card showed up in WinXP and both output audio just fine.
Try going into the BIOS upon booting to see if for some odd reason your onboard audio got disabled. If so, turn it back to "enabled". It should be under the category onboard periphials or something.. Look for "onboard audio" or "AC97".
BIOS seems to think that the audio device is on (auto setting), so it looks like I will have to get my hands on an audio card. Thanks for the help, and any other suggestions would be appreciated.
Thanks,
-Vito
