Sep 4, 2009 #1 A antok86 [H]F Junkie 2FA Joined Feb 26, 2006 Messages 8,695 will pluguging and unplugging a usb header on the mobo while the pc is on do any damage? or is it safe to do
Sep 5, 2009 #3 A antok86 [H]F Junkie 2FA Joined Feb 26, 2006 Messages 8,695 Zero82z said: If there's nothing plugged into the USB ports, it should be fine. Click to expand... nope nothing is plugged in
Sep 5, 2009 #4 Z Zero82z Fully [H] Joined Jan 20, 2004 Messages 27,897 Actually, even if there is something plugged in, it would still be okay. After thinking about it for a minute, I realized that it would essentially be the same thing as unplugging something from a normal USB port. Anyway, you're good to go.
