TheGameguru
- May 31, 2002
With room to "breathe" that is.. I've run 3 Card setups before with the cards essentially stacked side by side.. not really anxious to do that with these 290x's
considering AMD claims that the 290x in Crossfire can saturate the pcie 16x 3.0 bus, I'd probably go for an X79 board, or a board with plx chip(I think MSI makes one for Z87 boards)
http://www.overclock.net/t/1428344/...red-has-512-bit-4gb-memory/1000#post_20890405Why would you need it? It needs to be able to transfer that much data in that much time. While more speed and lanes will get it there faster, it only needs to be there by the deadline, which for a 60Hz monitor is 30 times every second for 2-card AFR.
For a 4k 60hz screen, it needs to be able to transfer a full 34MB of data every 33 milliseconds to get there by the deadline.
PCI-e 2.0 x8 (4GB/s) can transfer that in 8 milliseconds.
PCI-e 2.0 x8 can transfer one 1080p frame in 2 milliseconds.
Theoretically speaking, a PCI-e 2.0 x8 has enough speed to handle 4k eyefinity at 60hz. It would be like running crossfire in a PCI-e x2 slot, but you could. Practically speaking, you want a 2.0 x16 or 3.0 x8. Even at this most extreme of resolutions you still don't need a PCI-e 3.0 x16
oh, and because math:
PCI-e 3.0 x16 (16GB/s) can transfer 4k 60hz in 2 milliseconds.
PCI-e 3.0 x16 can transfer one 1080p frame in 0.5 milliseconds.
Pretty simple math to work out how much other resolutions and refresh rates will need.
Where did you read that ?
Brent said:This hardware DMA engines allow for direct access between the GPUs over the PCI-Express bus solely. AMD has said the video cards can saturate a PCIe 3.0 x16 bus bandwidth; 16GB/s bi-directional. If this is true, it is possible that gamers who are going with two R9 290's or R9 290X cards will now have a need to upgrade to PCIe 3.0 for the best performance. It makes your CPU and PCIe bus speed choice more important than it was in the past, where previously it made little or no difference. Certainly this will be something to go back and test with real world gaming and see if there is an impact.
