hatzitaskos
n00bie
- Aug 19, 2004
Hello, I have an Abit AV8 mobo, and am not really sure to what extent I should warrant the temps its utility, Abit EQ, is giving me.
The reason is I also have a hardware probe, and the two often give very different values. The truth is the hardware probe is not sitting between the heatsink and the cpu, but rather inside the heatsink, so there could very well be a (sizeable) discrepancy.
But it still doesn't make much sense. Without overclocking, when the two measurements agree, my Athlon 64 3500+ runs at around 40C under load. But right now, for example, Abit EQ is registering 65C. I have the Thermalright 948U, as well as decent airflow in a Xavier V Thermaltake case, so I find that measurement kind of hard to believe.
Should I trust the mobo? Could the bios measurement be innacurate? Is anyone else getting innacurate readings from the same mobo? If the mobo is right, 60+C is a bit too high for 24/7 use, isn't it?
