mobo suported memory
Nora
I'm considering the Asus P5B Deluxe mobo. In the Newegg board specs it saids:
"Notice: Only DDR2-800 memory supporting JEDEC approved 1.8V operation with timings of 5-5-5 or 6-6-6 is supported on Intel Desktop Boards based on Intel 965 Express Chipsets".
I've already got 2 gig of Corsair ddr 800 that according to PC Wizard will run at:
Voltage : SSTL 1.8v
Prefetch Buffer : 4-bit
Manufacture : Week 29 of 2006
Supported Frequencies : 270 MHz, 400 MHz
CAS Latency (tCL) : 4 clocks @270 MHz, 5 clocks @400 MHz
RAS to CAS (tRCD) : 4 clocks @270 MHz, 5 clocks @400 MHz
RAS Precharge (tRP) 4 clocks @270 MHz, 5 clocks @400 MHz
Cycle Time (tRAS) : 13 clocks @270 MHz, 18 clocks @400 MHz
Min TRC : 15 clocks @270 MHz, 22 clocks @400 MHz
Am I reading it correctly that this is compatable with the requirements of the P5B?
Yes, that Corsair DDR2-800 MHz memory you have it's compatible with the P5B Dlx.
Right now that RAM it's heavily underclocked (2x270=540 MHz :eek: ).
That's one of the reasons for a new mobo. The one I'm running now is a few years old, and will only see up to 533MHz for the ram, and 800 MHz fsb for the cpu. Time for an upgrade.
