I'm looking to build a new rig within the next few weeks and my brain is exhausted from all the research I've been doing so I need some solid suggestions for which mobo I should get.
This will be the platform for a
Athlon 64 X2 6000+
8800GTS 320MB
Patriot Extreme Performance 2GB DDR2 800
500GB 7200 RPM SATA
currently, I'm looking at the ASUS M2N-SLI deluxe:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131013
and the ASUS M2N32-SLI Deluxe:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131011R
Which one of them should I get or what other suggestions would you recommend within the $100-140 price range?
Athlon 64 X2 6000+
8800GTS 320MB
500GB 7200 RPM SATA
