Mobo recommendation for Brisbane
kamata
Hi,
I'm gathering a new computer. I want Athlon64 X2 3600+, Brisbane. Could anybody recommend me a mobo/RAM that would make best use of it in terms of performance?
I'm not going to buy more than one video card so I don't need CrossFire or a SLI solution. The aim is reasonably overclocked, silent, air cooled system or something in between.
I'm considering 670G, nVidia 550 and nVidia 570 Ultra chipsets.
Thanks!
I would have to reccomend this abit am2 ultra board as a very good all around board. i used 2 of these and 3 of the abit kn9s boards for a new office build. This ultra build[nf4 /model kn9] was a great o/clocker and stable as a rock. It also had the option of 2 ide ports vs 1 for the 570 ultra and also its alot cheaper 75.00 vs 109.00..The other 3 boards i used was the kn9s and they too were perfect builds but the kn9 ran cooler and had the 2 ide ports. Both o/clocked equally well. I see now newegg has the kn9s for 59.99 after the 20.00 rebate.. Really cant beat that price..So check out the newegg site for the abit boards..The only thing i did on both models was to update the bios to the latest first thing.all the ram i had worked perfect,I used gskill ddr2 800 and corsair xms ddr2 800. both were 1 gig setups 2/512 sticks..so I can honestly say the am2 series of abit boards are fine boards and very affordable..Like i said ive used a total of 5 of these boards in the last 3 weeks..The 20.00 rebate on the kn9s 550 board is a hard deal to pass up....
Thanks for shareing!
I just saw ASROCK ALIVEXFIRE-ESATA2 and I fell in love with it. For about $70 I get cold chipset, latest audio, PCI-E ethernet and above average overclocking capabilities. What's more the CrossFire option is there only if I decide to use it.
I'm off to the memory/video forum now.
I have it and so far I'm really impressed with it. I haven't crossfired it yet (and probably won't) but so far no complaints. Has good bios, gigabit ethernet, and the best onboard audio i've ever used. Easiest build ever in my sig. I get sketchy temps with coretemp, speedfan, and everest, but bios temps hover around 37-41C at full load. If you get this mobo, make sure to flash bios to 1.10 to get rev.G (Brisbane) cpu support.
I have had tremendous luck with my Biostar Tforce 550, and read many other good reviews. I took a 3600 x2 up to 2.6 ghz with it. Not bad for 150 dollars for chip and motherboard. Rock solid.
Price has fallen off the deep end now. Tforce mobo and 3600 Brisbane oem is around $130 at newegg now. The 3600 by itself is less than 70 bucks.
Thanks! What memory/video do you have? Have you clocked your memory?
Thanks! I considered it and decided not to go that way because the audio is very old and it has active cooling. What's more for some reason the price here (Bulgaria) is much higher.
I have a 3dconnect x1900gt and 1 gig of ocz gold ddr2 800. I haven't played with my memory clocks at all. I'm not much of an overclocker, but the options are definitely there in the bios. Some people say that the voltage can't be adjusted in bios, but that's not true. The bios is sorta 'foolproof' in that some options are hidden if others are enabled, such as am2 boost, which clocks your processor just a tad higher. If you disable am2 boost, you can adjust voltage timings.
