mobo/ram question
cwolf78
I have the Asus M3A32-MVP Deluxe mobo and I have 8 gigs of this Corsair DDR2 1066 RAM. I was reading somewhere that this board can only handle 1 stick of 1066 ram per DIMM. If I have all 8 Gigs on the board will it simply slow it down to 800 speed ? If so am I better off to just have 4 gig running at 1066 or all 8 gig going slower. I know it will recognize all 8 gig (at least Vista says it has 8 gigs) but I can't see any performance details about the speed.
Go to bios try to match up its speed to 1066 then boot up your computer. If it boots there is no problem. Then you may want to set the timings 5-5-5-15 is good with 1066mhz, you can 4-4-4-12 with 800mhz. I dont think you will have problem. i heard people run that memory over 1100mhz. And dont believe everything is said. Try and error is the best way to find out.
ok, I need to find those settings in the bios. I looked briefly at it last night and did not see anything about speeds of ram. I saw some stuff about ECC, but left it disabled. What is the 5-5-5-15 ?
check this out. it explains the logic.
and this 3rd picture fromthe top is how looks like my old motherboards memory timing bios page.
If you still cant do it post you memory bios page`s picture here, it might be more helpful.
Cool, thanks ! I will take a look at my settings when I get home from work.
Here it is...
