Lone_Bullet.be
- Jul 26, 2005
Hello,
2 days ago i bought a new system for a friend.
Now the combination of the ASUS P5B-VM + Intel E4300 and the Trancend JM388Q643A-8
does not seems to work ( 800MHz CL4 2x512Mb ). The system does post ( HD activity, fans spinning, LED's lighten up.) but no video output.
I tried different monitors and GPU ( the board has a PCIe 16x slot ) but without luck. I tried booting with 1 stick, other channels. Nothing either.
Can't swap out CPU/RAM because i don't have spare DDR2 material.
Their 677MHz version however, is listed on the ASUS Qualified Vendors List. But it's 677...
Now i do not have any experience with Intel CPU's nor DDR2 ram.
How wil the E4300 behave on the 677 speed? Much of a performance downgrade?
WILL it actually work ( you nvr know ). Plz answer as quickly as possible..
Ty !
Ty !
