mobo question
what all would i need to hook up for the new soundcard im going to get to work, obviously plug it in the pci port disable onboard sound but anything else? im getting audigy 2 zs and i have an Asus a7v600
make absolutely sure you remove all the onboard sound drivers. Also, you may need to reinstall direct X...
Hi:
You probably are running XP, but if not, the audigy series will not work with any version of Win 98. It should work ok with ME. Also, there is probably no SB16 compatability.
There is a CD audio cable that needs to run from your cdrom/burner/whatever. Connect that to your sound card to play/rip audio cds.
