mobo question abit or biostar
flake4200
i am trying to pick out a new board and i on kow which one to pickout. i am either going to get the biostar 770 board. or the abit ax78. can smeoe help meon which n to get? thnks for the help. by the way i am going to have a 5000 blk in it.
abit ax78 is a great board, it is the only 770 that uses Xfire (despite using 4x PCI-E speeds on the 2nd slot, but still fast). The ClearCMOS switch in the back I/O Panel is a fantastic idea.
However, I know for sure the Biostar can't handle the 125W Phenoms while the ax78 is a mix. I had the abit ax78 and it had problems with the Phenom 9850BE even at stock speeds, but other ppl seem to be ok.
Biostar makes good boards but the Ax78 is definitely a better choice.
well, not for the phenoms but for the 6000 it does. 125w is 125w. weather its a phenom or a x2
I haven't run the Biostar but the AX78 is good.
1 of the guys on the abit forum between him & his brother has used both & he seems to slightly give the nod to the abit over the Biostar.
