Mobo Problems
MattD
i just installed my abit NF7-S2, and i have everything connected...turned it on, the fans come on and then it just shuts off. LED1 (5vSB) stays red but the LED2 (VCC) comes on green but then goes off.... is my power supply bad?
well i put a new power supply in, i have disconnected everything and re connected it numourus times and still no luck.... i even did the bench test with the mobo outside of the case and it still only stayed on for a couple of seconds....it will turn on, then shut off... ive read thru the manual more times then i can count. would a bad video card shut it down? the fan on the video card when powered on kinda stumbles around, while all the other fans spin at normal rpms...
Had a similar problem try resetting your cpu and your heatsink back in or try a different video card. :
