Mobo problem?
bmoney9
Hey All,
I have the following:
Asus p8z77 v-deluxe mobo
ivybridge 3570k
2x8gb 2000mhz
antec 1200w psu
The other day was watching a movie on Amazon Prime. In the middle of it, computer shut off completely. Figured it was the 24 pin connecting to the mobo was not secure. Bent the 24 connector pins closer together and that did not fix it.
The only things that happens when you push the power button is the fans turn on for a half second then off. The red CPU led comes on then off too. Not sure what the problem is.
Any ideas? Tried moving ram around. Checked the cpu itself and no bent pins. Confused.....
Thanks in advance.
