Mobo problem or HD problem?
mattm
I have a TYAN S2875ANRF, It's been running Windows XP for a while now. It primarily is just used for Adobe CS and other photo applications.
Recently, it was reported that the system would freeze, then lock up and crash. Also, the machine is installed with 4GB of memory. The user reported Windows is only reporting 3GB worth of memory. ( I forget what the max registered memory XP Pro can handle)
The HD's in this system are 2 74GB Raptors. They are plugged directly into SATA1 & 2 of the MoBo. When I went to reinstall windows, the isntallation screen didn't pick up the Harddrive, stating there was none detected. I put the onboard SATA drivers on a floppy and loaded them in the third party adapters screen of the isntallation, and still no luck.
I tried plugging in both Raptors in SATA1 and even purchased a 3rd to test with no luck. Has anyone else run into this problem before on the Tyan board, is there something I'm overlooking? Thanks in advance. :confused:
are the raptors in a raid array? you may need the raid drivers for the setup rather than the normal sata drivers.
are you sure the drivers are extracted etc on the floppy?
Not doing any RAID array on this box. Yea, the drivers are there correctly, they appear on the screen after loading the 3rd party drivers - yet no drive gets discovered.
I had a similar issue with a A64 3700+ would not see the hard drive in SATA, so I buy a new ide drive works, until I restart and it won't see the drive. Replaced the PSU and everything is hunky dory. It was undervolting the hard drives so they were not showing up. Possibly PSU. That is just my opinion though. Good luck on your endevors.
It's possible the PSU might not be able to power both opterons, 4Gb of memory 2 DVD drives, 2 Raptors, and an Nvidia 7600GT....it's an OCZ Modstream 550W.
The PSU in this box was enough but it was flaking out so it would sometimes provide enough juice then others it just would blue screen. Crazy but PSU's account for more hardware issues than not. OCZ is a good brand could possibly have too much for it or it is going south.
Standard PS calculators chime this system in right below 400W and during an install I would doubt the CPU utilization is anything major...it's still a valid point though.
If you had a spare you could try before ordering a new one or just hook up your raid drives and remove some of your memory just to test.
