Soarin
- Jul 23, 2010
Here are my system specs folr the mobo and cpu and like I said I think one of my devices are going out
Motherboard
Manufacturer ASUSTeK COMPUTER INC.
Model P8Z77-V LK (LGA1155)
Version Rev X.0x
Chipset Vendor Intel
Chipset Model Sandy Bridge
Chipset Revision 09
Southbridge Vendor Intel
Southbridge Model Z77
Southbridge Revision 04
Cores 4
Threads 4
Name Intel Core i5 2500K
Code Name Sandy Bridge
Package Socket 1155 LGA
Technology 32nm
Specification Intel Core i5-2500K CPU @ 3.30GHz
But whats going on is the system will try and boot up but then it shuts down,tries again and it may boot but normally it goes down and tries again until it finally boots. When I say boot I dont mean all the way to the desktop I just mean to even bios loading. I am 99% sure it is not the psu because when I check the voltage it stays constant under load. The cpu and mobo are both old and used as well. I need to figure this out and get things replaced soon because my wife starts school tomorrow and needs the desktop running perfect.
Anyways, could someone recommend troubleshooting tips or should I just replace the main 3?
I plan on replacing the mobo ram and cpu with these below but still am undecided. I know anything will really be an upgrade. Also too, are there any mobos with the 350 chipset that will work with the ryzen? I really dont want to go asus, and the other boards got crappy reviews.
Component Selection Price
CPU
AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor
$149.99 Buy
Motherboard
Asus - PRIME B450M-A/CSM Micro ATX AM4 Motherboard
$79.89 Buy
Memory
Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-2400 Memory
Motherboard
Version Rev X.0x
Chipset Revision 09
Cores 4
Threads 4
Technology 32nm
CPU
$149.99 Buy
Motherboard
$79.89 Buy
Memory
