Need help guys
pc was running fine, no issues or hints of impending doom but now suddenly in getting a bsod "Whea uncorrectable error". I had played some VR and assassin's Creed oydessy the night before with no issues. Today I went to log into it from work (shout-out TeamViewer) and noticed it wasn't online. Figured that was weird but my wife has shut it down on me before so I didn't worry.
Specs are
4670k @ 4500mhz prime tested stable (water cooled 30c idle 69load in prime)
Asustek gryphon z87
4x 8gb g-skill ripjaw X f3-12800cl
Gigabyte 1080
Got home and found it frozen, rebooted it and now I'm greeted by the whea error on boot. Here is every troubleshooting steps I've done.
\- Reset bios to factory
\- Removed the GPU and went to intergrated GPU
\- went to 1 stick of ram, tried in all slots then tried a second stick
\- cleaned and remounted heat sink, also tried a spare heat sink
\-removed all other hard drives
\- booting into safe mode (crashes just as fast)
CPU is sitting at 23C according to the bios, and during gaming I never seen temps above 65c with my OC. Whats more worrysome is I get this error when attempting to reinstall Windows 10 to another SSD. I can't even make it to the selecting the drive for install before it crashes. So far based on this I've ruled out ram, hard drives and you errors. Is there anything else I can try? Is there a way to test the mobo/CPU without having a donor cpu or mobo?
Specs are
Asustek gryphon z87
Gigabyte 1080
