Mobo Options... Opinions?
Spiffy577
Hello all,
Oh man... I have really been out of this for a while and I have NO idea of what to get. I am looking to build a new machine for some major video editing. I don't have a ton of money but I have a few bucks. I really need it to do / have the following:
1) Serious video editing (better chip to handle it?)
2) Onboard firewire (MUST have) / lan / and decent 5.1 sound (would be nice)
3) Probably Intel dual core?
4) I would like sata but I have a bunch of standard ide drives laying around. Would like to support both, without comprimising speed.
Now I need a machine that is going to handle some pretty high end video editing. Thus I will need a decent processor with probably 2 gb of ram and a video card with capture capability (if I need it). I was looking all over and it still seems that asus, abit, gigabyte and mbi are the best boards, am I correct? I also notice that Nvidia, SLI, and Intel are the best chipsets, correct?
Ok, so PLEASE anyone, any suggestions?
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=535318
This'll work, aBit QuadGT, covers all your specifications (though only max of 2 IDE drives but that's typical on any new board).
Pick up a QX6800 (video editing is just about the only reason to own a Quad Core), 2GB of RAM and then the video card depends on your budget and needs, the ideal range are the Nvidia Quadro FX series (e.g. FX4600), but they cost a lot lot more than the same gaming cards.
Yes a quad core would be really nice but the prices I am seeing on that is 1400. THAT is a bit much. I was hoping to spend about 1400 total if possible.
Maybe power system on SOME budget... hehe.... :)
Keep going though! Thank you!
Well, out of that budget, this processor would work Q6600. Sure, it's nearly half your budget but there's definate advantages to that processor over the 2 core models.
RAM doesn't matter *too* much, get a little overhead just in case you upgrade to a FSB1333 processor in the future, Corsair Value Select DDR2 PC5300
Graphics card will be dictated pretty much by whatever's left to be honest, there's no specific advantage to either ATi or Nvidia if you can't afford to get an GeForce 8x00 series card, though ATi X1950 Pro is well spoken of for it's price bracket.
