Jan 27, 2004 #1 R renegadez Limp Gawd Joined Aug 9, 2002 Messages 271 I have an asus p4s533-x here which is my friends are there any known issues with this board? if you do not plug in that 4 pin plug that goes into the mobo can it mess up the mobo?
Jan 27, 2004 #2 M Master [H] 2[H]4U Joined Mar 17, 2003 Messages 2,629 Usually, the extra 4-pin connector not being plugged in results in the system not powering up or possibly instability.
Jan 27, 2004 #3 R Roost426 Limp Gawd Joined Dec 18, 2003 Messages 447 Yes the 4 pin connector most definetely needs to be connected.
Jan 28, 2004 #4 R renegadez Limp Gawd Joined Aug 9, 2002 Messages 271 that could be why sometimes the computer doesn't boot up and sometimes it does right? do you guys have any clue why it boots sometimes and doesn't sometimes? first couple of times it doesn't boot...then when u try again it boots and boots fine after that but when u leave it for a while it doesn't boot at first
