The Chosen One
- Feb 4, 2001
Hi guys, im just putting together a cheapo Fax server for work, and ive run into a rather odd problem. When i have the HDD and DVD connected to the Primary IDE Channel...BIOS wont recognise them, but when i connect them to the Secondary IDE Channel....works fine.
Anyone got any ideas how to fix this? or is it just a faulty mobo?
Also, if its unfixable, how marked is the performance drop by running your primary HDD on the secondary channel?
because if its not too bad i really cant be stuffed returning it to the wholesaler cos it will take them weeks to sort out the problem, and ill only get a credit back after it all anyway, just too many hassles.
Here are the specs:
Abit KV-85
Sempron 2800+ s754
512mb DDR
D-Link Fax/Modem
D-Link DMT-530T Gb Lan Card
Lite-On DVD Reader.
Any ideas? thanks in advance guys
Here are the specs:
Abit KV-85
Sempron 2800+ s754
512mb DDR
D-Link Fax/Modem
Lite-On DVD Reader.
