Mobo message from the dead?
Last night my PSU seemed to have fried, nothing would start yadda yadda. So today i went out purchased a new Antec for 60$ and started up again. After about 7 seconds the computer shut off. Now each time the computer will start running for just a second or two long enough to start the fan. Unplugged all the sockets except to the mother board and now it wont start up no matter what is plugged in. All that shows any life of the computer is a flashing LED on the front of the case and the little yellow light the the ethernet port. Does this mean anything, and how can i find out what it is? could it be the mobo telling my something?
this is my mobo:
http://www.newegg.com/Product/Product.asp?Item=13-130-457R&type=Refurbished
well i could. but theres no point. im not going to use generic one that came with the case anymore.
No, i wanted you to test the new PSU, the Antec. Coz it sounds an awful lot like what happens when cheapo PSUs fry on me. Although, it being new and an Antec, it shouldnt have happened.
yeah. thats what leads me to think whatever happened to the PSU could have fried something else as well. likely the mobo since i tried unplugging stuff and it still does nothing.
Well, that's true. I'd suggest either the mobo or the PSU, but you will have to test both before you can determine which one it is.
test bench the board, ram and proc only reset the bios befor first boot should give you beep code saying no vid, if you get nothing chances are the board is dead... and in parts one at a time vid then keyboard, mouse, hd's ,cd-roms it takes time... but if your old psu took out a cd-rom it will keep the whole thing from booting it could be any number of things start there and you'l get a quick answer
