Mobo installation problem-MSI 865PE
[Fate]Doom
After finishing the hardware installation I booted up and the processor read and posted correctly at P4 2.8ghz.
At this point the next line gave me a couple of set-up options, but none of them could be selected. Right below that it said it was starting "Flash Recovery", but kept getting hung up.
If I selected "skip" it would give me prompts to start windows in safe, normal, or DOS. All selections just cause the system to reset without ever getting to windows to make corrections.
I am booting this from a HD that was being used on a different mobo and CPU. All other hardware is the same like the Vid Card, Wireless, Sound Card, and the OS is still Windows XP.
I am sure there ,might be some issues becasue of this. Any help would be great.
Windows might not have drivers built in for your chipset components, that's why it's reccomended usualy to format when you change your mobo.
