Hey all, so I built a box for my folks. It's is a
q6600
Gigabyte P35 mobo
4 GB ram (1x4 sticks)
WD Blue 500 GB HD.
Corsair 500 watt PSU
Elcheapo case
Radeon 5450
The machine has refused to boot for a while, and after exausting all options I decided it was the mainboard. I borrowed a similar mainboard from a friend (unused RMA refurb) and it is DOA as well. I tested the PSU on a different box and I tried different processors. I am not 100% sure it is the motherboard -- but I think it is a pretty good bet. So, I am trying to decide what to do about it. I don't see any motherboard for 775 that has four RAM slots out there -- most of the ones that exist at all are microatx P45 boards. This box is used for web browsing and office productivity, so it doesn't need much horsepower. Anyone have suggestions of a good replacement board if I assume the ram and CPU are OK?
My other option is to do CPU/RAM/MOBO for them. Everything else is fine. My hunch is for a sandybridge I3, but that may be more horsies than they need. I don't know enough about AMD to make an edumacated decision -- Anyone have advice on a replacement CPU/RAM/MOBO?
web browsing, no gaming, minimal photo editing, no video, office productivity.
< 250, but the cheaper the better.
US, Colorado -- no microcenter nearby.
CPU, Mobo, RAM
Corsair HDX520 PSU, Hard Drive, DVD drive (although it is a PATA drive), case, Radeo 5450
6) Will you be overclocking?
Nope.
Unsure, far less than 1080p.
immediately.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
On board audio.
Win7 64.
Thanks for any advice here!
q6600
Gigabyte P35 mobo
WD Blue 500 GB HD.
Elcheapo case
Radeon 5450
CPU, Mobo, RAM
Nope.
immediately.
On board audio.
Win7 64.
