Mobo heatsink question
locutus24
Looking through heatsinks to cool my 462 setup, and then came across a warning that says not to put to heavy of a hsf on the mobo clamps.
Zalman
Wanted to get this but it is Weight: 755g, and the warning said that a 462 should only have something up to 300g. Should i be concerned about putting such a heavy hsf on my board, and by the way if this helps any i have a DFI lanparty board.
good question.
And I'm kind of curious 'cause I have the same DFI board. (good choice too)
It's only really an issue if the CPU core is directly in contact with the heavy heatsink. So, a normal desktop s754 will be protected by the aluminum IHS cover. But the IHS'less 1mb chips might be a problem because the heatsink also doesn't sit down all the way onto the bare core, with the stock DFI bracket. Someone who has experience with this, please help us out here.
