MOBO graphics question
This is the MOBO I have, will it support a single or dual slot graphics card? and what size graphics card? (the actual physical size) http://www.newegg.com/Product/Image...P5K-E LGA 775 Intel P35 ATX Intel Motherboard
Your question is slightly unclear to me. If you are asking if the motherboard will support a video which physically covers two slots, the answer is yes.
If you are asking if the motherboard will use two different video cards at the same time (SLI), then I think it will do that too, but if video cards are in both slots, one will run at x16 and x4, which means you would not get the full power of the second card.
As far as the length and size of the card, the bigger question is what size will fit in your case, as some computer cases don't have room for the longest video cards. Depending on the length of your card, you might block some of your SATA ports, but some of that can be cured with 90 degree SATA cables.
FYI, if you include the specs of the motherboard along with the pictures, it does make it easier to answer questions about the motherboard.
edit: Hence, why I should have looked at the specs before typing...the P35 chipset seems to only support CrossFire, which is out of my experience since I only buy nVidia cards. :D
The P35 chipset (the chipset that the P5K-E uses) supports only CrossFire. It does not support SLI at all. In addition, the P35 chipset supports CrossFire only in an imbalanced x16/x4 mode (and is of only PCI-e 1.1 spec, not PCI-e 2.0 spec, effectively cutting the bandwidth to today's cards to x8/x2 mode, resulting in the higher-end of today's cards now being bottlenecked seriously if operated in this mode).
