MoBo fried? AARRRGGG!!!
JimmyChunX
okay somehow my pc won't turn on at all... no power... no nothing...
I replaced my PSU to a 550w I3@I)@$$ from a 375w POS... reconnected all the power wires and connections needed to power all components (no mouse or keyboard or anything)... turned on just to test it was right... It turned on just fine. I let it run for like 2 minutes with no problems... I do a hard shut down (hold power till off). No funny noises... no flashing lights... no puffs of smoke... no burnt smells... I assume it turned off just fine as I've done it plenty of times before, just not with this PSU. I turn the main power switch on PSU to off as well and unplug it.
I then commense with the second half of my project. I remove heatsink... remove old cpu... insert new athlon xp 3000+ barton... (with thermal grease of course)... replace heatsink... add 512 stick of mem... plug power back in... turn main switch on PSU on... push power button and nothing... not a damn thing... when I say nothing, I'm not exaggerating. I mean absolutely nothing. No lights, no fans, no noise except for the PSU which has a fan that when the main switch is on it runs even when the comp is off... the fan ran like this even when I tested it the first time, so no concern. My MoBo is getting NO POWER, but PSU is...
I re-attached old PSU just to test it and no luck there either... same thing... I don't see how the new cpu or mem could possibly cause this... I checked the wires and connections for the power button, they look fine visually... and unplugged and replugged both the MoBo power connections god knows how many times... what's going on?...
Somebody tell me my MoBo isn't fried... I just got it and I don't have the money to just be throwing into new MoBo's every month. Tell me it's something else... I didn't do anything that would've done this that I can think of... AAARRGGGG!!! I just bought a bunch of parts for this thing and now it's busted!!! HHHEEELLLPPP!!!
Your MoBo isn't fried....I am betting on the CPU. With the Bartons it is very easy to use too much grease and short out the processor. Did any of the paste get on the chip itself? Sometimes you can wipe it off and it will work again...sometimes you can't. Good luck!
odd, although I've had crazy things like that happen to me. Try to cut the power off via the back of the PSU, reset cmos, then turn it back on and see if it powers then.
It could be possible that you put too much compound on it and shorted out the CPU, however, that'd only happen with a silver based compound, wouldn't it? Try to put back in your old CPU yet?
replacing the old cpu is the next logical step and I've been meaning to the past 2 days ever since it happened but haven't had the time... and really haven't felt like all the trouble. The whole situation just aggravates the hell outta me everytime I think about it... I suppose I'll do it tonight... just suck it up and do it... it needs to be done before I start going into WoW withdrawels!!
I had a friend tell me that a bad cpu will keep the mobo from powering on... hhhmmmm? I guess I'll find out tonight when I put the old cpu back in...
Does anybody else have any ideas on what might've happened or what other troubleshooting steps I should take?
Happened to me, pressed power and nothing happened, replaced mobo and now it works.
check the power supply.
There is a bios battery on the mobo that stores the memory
if that goes that could happen.
Try resetting the Bios
the mobo has a jumper somewhere
you discconnect the AC power wire
then move the jumper to the two other pins for a few seconds
then move it back
connect AC
fire it up
you will have to reset all your bios settings if you do this
I have a flaky mobo that this works when it does that
okay... why would bios settings keep the mobo from getting any power?
My mobo has a 2 digit LED display that lights up to give me error messages... no lights... nothing...
I can sort of see how a bad cpu can cause this... because without a brain the body can't really do anything even if it DOES have power...
i'm sorry if you don't understand the metaphor... think about it...
I'm too lazy to mess with the cpu again tonight... I work swings and when I get home at 10:30 the fiance always has something for me to do... so that pretty much spoils the mood and makes replacing the cpu seem like work again.
when they get flaky try anything
mine only lets me put memory in the 3rd slot
the hard drive connectors don't all work
when i boot up i only get the start screen or nothing
i hear the fan go on but blank
then i short the bios jumper and it works fine
try it can't hurt
you have the rest the CPU clock speed and bios settings
i am going to relace mine this week
I had enough and it might totally go
they won't get any better
I have the same board but not the PRO version, and it's still a very good board you have. I love my 8RDA3+ as it has overclocking options similar to the Abit NF7-S, but the problem you have sounds like the CPU was already dead before inserting, did you buy it from a store or a person? Put your 2100+ back in there. If it works, then the 3000+ is kaput. You can turn the 2100+ into a 2700+ by putting the FSB to 166 and CPU's vCore to 1.675. It's what I did to mine in my computer, I have the same chip, it's identified as 2700+ in the BIOS and in Windows. Gets a nice performance boost. (1.73GHz vs 2.17GHz)
How old is your Epox board?
I'm asking only because a lot of the older ones were stuffed with crummy caps, the newer ones have better caps in them.
Sure as sh*t when I put the old cpu back in it booted right up... looks like I have a bad 3000+. I'm going to wipe off all the thermal paste and try hooking it back up with much less and see if that helps. Probably not...
The thing is I bought the Barton from somebody on this forum along with a stick of mem...
I'll see what he has to say for himself before I go droppin his name though...
I cleaned that cpu up like there never was thermal paste on it... put a little on top... installed it... nothing once again... hhhmmmm...
the mem works though...
let's see what the response from unsaid seller is...
on a side note... my cpu is suppose to run at 333fsb but when I set the mobo to 166mHz (333) it won't let it run. It forces me to go back into the bios and change it. It's done this since I got the board a month or 2 ago. Anybody know why?
Check your caps, check your battery that backs up the bios, check the +5vsb output of your power supply.
