Mobo for ivy bridge
tpfaff
Will any sandy bridge p67 serve well as a mobo for ivy bridge? Is ivy bridge going to bring a new chipset with it? I'm looking to get a sandy bridge mobo and i3 and later on get a nice ivy cpu. What do you guys think?
Yes you can use P67/Z68 mobo for Ivy Bridge with no problems. The only issues could be the Dram volttage, as far as i heard it will operate at 1.35v, and it has to be at least 1600mhz.
I'm no expert but from what I have heard the Z68 will work but you will need to update the mobo Bios to a newer version and possibly the chipset firmware. Bios updates are pretty easy now. I never have updated a chipset firmware so not sure how its done or how hard it is. I'll assume its as easy as a Bios update. I dont know if the P67 can be updated or not. I hadnt heard if it is.
