Mobo for in-law...
SmAw
Thinking about getting this for mother-in-law for a simple desktop computer to email and web browse. What do you guys think?
Model
Brand BIOSTAR
Model GEFORCE 6100-M9
Supported CPU
CPU Socket Type Socket 939
CPU Type Athlon 64 X2 / Athlon 64 FX / Athlon 64
FSB 1000MHz Hyper Transport (2000 MT/s)
Chipsets
North Bridge NVIDIA GeForce 6100
South Bridge NVIDIA nForce 410
Memory
Number of Memory Slots 4×184pin
Memory Standard DDR 400
Maximum Memory Supported 4GB
Dual Channel Supported Yes
Expansion Slots
PCI Express x16 1
PCI Express x1 1
PCI Slots 2
Storage Devices
PATA 2 x ATA100 up to 4 Devices
SATA 3Gb/s 2
SATA RAID 0/1
Onboard Video
Onboard Video Chipset NVIDIA GeForce 6100
Onboard Audio
Audio Chipset Realtek ALC655
Audio Channels 6 Channels
Onboard LAN
LAN Chipset Realtek 8201BL PHY
Max LAN Speed 10/100Mbps
Rear Panel Ports
PS/2 2
COM 1
LPT 1
Video Ports D-Sub
USB 4 x USB 2.0
Audio Ports 3 Ports
Onboard USB
Onboard USB 2 x USB 2.0 connectors support 4 ports
Physical Spec
Form Factor Micro ATX
Dimensions 9.6" x 9.6"
Features
Power Pin 24 Pin
Packaging
Package Contents GEFORCE 6100-M9
User Manual
Driver Disk
Rear I/O Panel Shield
IDE/PATA Cable
FDD Cable
SATA Cable
guess that means no...she doesn't do anything but surf the web and email...its a good deal...68 bucks with the prossesor...
It will do what she wants, assuming you use XP rather than Vista, or disable Aero in Vista.
I /would/ suggest you get a socket AM2 board/chip though. There is nothing new coming out for socket 939 anymore, but AMD claims AM3 will be backward compatible with AM2, so you're going from a dead upgrade path to a live one, and that's worth some cash.
Also, DDR is pretty much dead as well... and with DDR2-667 prices so low ($70 or less for a 2GB, 1GBx2 kit) and DDR2-800 only slightly higher, there's really no reason not to get faster RAM as well. Most AM2 boards will run DDR2, if not pretty much all.
