Always wanted to build a X99 rig. Looking for a board with overclocking optionsr that will allow me to push the chip to at lest 4.2 but I don't care about things like wireless, Bluetooth, dual LAN, OC panel- stuff like that
Prefer to stick with Asus or Asrock as I've had minimal issues using those brands. Gigabyte can go die in an electrical fire. Haven't used MSI since 939 days
System will be multipurpose- gaming, video editing, light photoshop work, etc
Other components I'll use for the build:
Win 10 Pro 64 will be OS
BeQuiet 1200 watt psu
Thermaltake 3.0 360 AIO
2x GTX 1080ti
1 TB regular SSD for boot drive
2 X 6 TB WD Black spinners
32 GB . Skill F4-3200C14Q-32GTZ (might add another kit later)
Budget is 300-ish. Price really isn't too much of a concern I just dislike paying for things I'll probably never use.
Another thing I did note as I was researching is that many of the X99 boards will only support the 6850K if it has the latest bios. Are new boads shipping with the latest bios installed? Hate to have hold off on the build just to find a different cpu that will work only so that I can update the bios in order for the 6850 to work
Thanks for your time
2x GTX 1080ti
