Mobo dying slowly
Stoly
I have an MSI P35 board.
About a couple of years ago I started having problems with my HDD. BSODs, lockups, failing to boot and other instabilities.
The problem was the SATA port 3, I moved the HDD to another port and problem solved. months later, SATA port 4 started giving the same problem. So I moved to SATA 2. Again problem solved. So far the remaining 2 ports work.
early this year the front USB ports failed randomly to recognize USB devices. And just last week the ethernet port started to "freeze". It will work for a while and then stop working, no device error, it just won't send/recieve data. I put an old realtek network card and now its working properly.
I'm not really looking for a fix. But its the first time I have a mobo die one part at a time.
Anyone seen something like this before?
Well if you remember they recalled all the first sets of p67 boards because of the Sata ports decaying over time. Slowly decreasing performance until complete system failure. So I'm sure this has happened to other boards before. It does sound strange that other all the other things started to give out to, but sound like time for a new MB
certainly, but since its not my main pc and cpu/ram/video works ok, I see no need to do it just yet.
Had this happen on a VERY similar mobo MSI p45 neo, USB's started getting knocked out, then sata ports and LAN port. RMA'ed it and sold the replacement board and moved to better brands of mobo's and never a problem since (ASUS, Gigabyte)
Really? I've owned a few MSI boards and didn't have any issues until now. I still have a MSI Nforce3 board for an Athlon 64 and it runs quite well.
But now that you mention, I don't think I'll get one again. I'm going for asrock for my next upgrade.
New simptom. Memory problem. It currently has a single 1gb DDR400. Yesterday windows was very unstable, multiple errors, restarts, BSOD, failed boots.
The only cure was to run the memory at 333 with loose timings and 2.55 v.
I've tested the memory on another pc and it works at DDR400, I also tested two different working sticks on the MSI. One failed to post and the other only worked with the settings above.
ddr400? really?
anyways, i'm assuming 5+ years old. i don't know how much you used it either but it sounds like ESD damage is slowly taking its toll. Toss it, it's only going to get worse.
