Mobo died, need replacement advice
asyork
Edit:
Thanks for the help. I ended up finding another x58 sli le in evga's b stock for $80. It's a bummer to spend cash without an upgrade, but it's also a bummer to have to upgrade when what I had was still more than sufficient for my needs.
The motherboard from the build in my sig is dead. I would prefer not to replace it with another x58 unless I can find a used one at a good price. I haven't been keeping up with the new sockets/chipsets since I built my current comp, and I need to have it running again asap for work.
I mostly use it for gaming and web browsing as far as time goes, but it primarily needs to be able to run Photoshop CS4 and Lightroom 3 with large batch processes.
I'm trying to keep it close to $200 because that is about what it would cost for me to buy an equivalent x58 motherboard new. If I would end up with a faster CPU and/or USB3/sata6 then I would probably be willing to spend about $250 with tax and shipping included.
3) Where do you live?
About 45 minutes west of the Greater Atlanta/Marietta Microcenter. Too far from Fry's unless they have a deal that would be worth the extra time and $20 in gas.
Motherboard and CPU unless my budget is too tight and I have to just go with another x58.
Everything in my sig. Unless I missed some huge change (like another CPU power connector), then everything I have should work with a new CPU/mobo.
6) Will you be overclocking?
It isn't important to me, but if there is a cheaper and easily OCable part that makes since then I can do it. I plan to use stock cooling though, so if I would need to buy aftermarket cooling to do it, then that will need to be part of my price.
23" 1920x1080 and a 17" 1440x900. I don't game on the 17", it just gives me some extra room for windows and Photoshop tools.
ASAP, but I can survive on my laptop for a week or two if needed. I'd prefer to be able to go to Microcenter and get the parts this weekend.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
I don't "need" any of those, but if I am going with a new chipset, then I would like to at least have USB 3.0 on it. My GPU is out for RMA right now, so onboard video would be useful for a few days, but not necessary.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? I have Win7 64 bit already installed, and I am hoping I can just reactivate it and use the same install.
There's really nothing on the AMD side that's worth buying and the Sandy Bridge "equivalent" processor (Core i7 2600/2600K) and board would cost you over $300. You need to either up your budget to at least $400 or find out whether or not you could RMA your board for a replacement.
Is your copy of Windows an OEM or a retail version? I ask because you can transfer a retail version over to a new system, but not the OEM version.
I believe it was the retail upgrade version. I know it wasn't the OEM version. I'll check again, but I'm pretty sure my board is out of warranty.
For $200 or less, I recommend a new X58 board. Anything from Asus, Gigabyte, MSI, or EVGA would be good; just pick one based on your immediate needs.
AMD's current AM3 lineup is more of a horizontal switch in terms of performance. Though Sandy Bridge would give you better long-term options, X58 still holds some advantages over P67/Z68 due to its extra PCI-E lanes and ability to use more RAM.
My board is out of warranty.
I just gave myself a wikipedia crash course on sandy bridge and LGA 1155 options. If I moved to 1155 I would lose some ram in the short term, but I could eventually get a 4x4 kit and be happy. I also don't need the extra PCIe lanes. Basically, I don't want to end up handicapping what I intend to use. As per the info on [ame="http://en.wikipedia.org/wiki/LGA_1155"]LGA 1155 - Wikipedia, the free encyclopedia[/ame], it doesn't look like I'd lose anything I need even going to H67.
How would an i5 2400 compare to an i7 920? My 920 is at stock, and I wouldn't bother OCing it anyway. At MC, the 2400 is $150 and the 2500k is $180. They don't have the non k version :/
After rebates ($40 IR and $10 MIR), I could get the i5 2400 and http://www.newegg.com/Product/Product.aspx?Item=N82E16813128495 from MC for $220 + tax.
This is all based on my brief research on wikipedia and a little googling, so I'm just throwing it out there for you guys to tear apart.
If I go with a new x58 board, the EVGA sli 3 seems to be most similar to my current board. I'll probably look around for something cheaper though since I am just using 1 GPU and onboard sound. I found some used x58 boards in the fs/ft forum for as little as $99 shipped, I'm undecided on being comfortable buying a used motherboard though.
edit: I guess there is no good way to link to wikipedia now... Even editing that out it just adds it right back with all 3 links when I save the post.
If the Gigabyte Z68 board fits your needs, then that combo with the i5-2400 would be fine.
All of the Core i7 processors come with Hyper Threading, but I can't recall how much of a performance boost Hyper Threading gives in Photoshop/Lightroom-related tasks and benchmarks.
