Mobo died, need recommendations
Karandras
Hey all, here is the situation:
My Parent's computer was running like crap. Utra mega super slow kinda thing. So I was working on backing up data when the whole computer lost power. Odd, but whatever, tried to replace the power cord and it worked. Even odder but whatever it booted. When it came up into windows, I tried to do stuff but the mouse and keyboard was dead. So I tried another set, no change, tried just the keyboard, no change :-/ So I've figured its just the motherboard.
Now their computer is my old old computer, here are the specs:
P2-350 (Slot 1)
128 Meg PC133
3 Gig HDD
Onboard Sound and Video
D-Link NIC.
Generic Case and power supply (these were just replaced about 6 months ago)
So here is the big problem. I've tried to search for a slot 1 mobo w/audio and video on board, its tough. Now unless someone here can donate one to my cause I'm going to have to try something different. I have a few pieces left over from my upgrade:
Duron 850
256 Meg PC2700
Stock AMD HSF
TT Volcano 7+
So all I would need would be the mobo with the sound and video on board and I could make their system quite a lot better. Just need to get them a better HDD but thats later
Now can anyone recommend a Duron motherboard that is cheap and stable for a stock system? Must have onboard sound and video.
Thanks everyone!
Biostar M7VIZ
Shuttle MK43 (or was it MK40....)
MSI KM2M-L or KM4M-L
I've beeing looking more into this and I've found this one and its $69. Asrock K7S41GX SiS741GX? Anyone heard good or bad things about it? Its fully loaded, the only bad this is its a 64 meg shared memory onboard video. Thats a big jump for my parents from their 8 meg card ;-)
Schro, thanks for the input but I can't find those localy here. Must be a Canada thing :-/
www.ncix.com
Good rep from what the folks in the great white north tell me. You might find one of those on there. Generally, you should stick to brands you trust most. Personally, Asus, Abit, Gigabyte and MSI are what I tend to use. I haven't been all that enthused with the newer stuff from Epox, although their older boards seem to be some real champs.
Asrock is Asus answer to ECS...sooo, you're not quite getting the quality of real Asus boards. For on-board video, you should be able to adjust the shared memory size.
Yeah, I was all set to get one of those boards but I've had a couple bad reviews about them already (locally) saying that the sound chip started conflicting with the NIC and the only way around it was to disable to sound. Many problems with the BIOS as well. Still looking right now. Love it when its slow at work :-D
Unless you can find a board for free or less than $20, I'd just tell them that the machine is too old to find parts for it, and needs to be replaced.
Yup, thats pretty much what I'm doing and trying to find a good all-in-one mobo now to put my old duron 850 and ram and such in for them now.
I found a couple more motherboards that I would like som input on:
Asus A7V8X-MX w/ V/A/L
MSI KM4M-L VIA KM400 Audio Video L
Gigabyte GA-7VM400 w/ V/A/L
Gigabyte 7VKML W/ONBOARD SOUND, VIDEO & LAN
LAN isn't a biggie since they have a NIC already, but all these boards are below $100 CDN which is where I'm trying to stay.
Any good/bad comments for these?
Thanks again!
:confused: Still trying to find the best bang for the buck :-/ Anyone recommend or hate any of the above mobos?
thanks!
Why must it have onboard stuff? I mean, you can get some really cheap video cards (like a TNT or something maybe,) soundcards are dirt cheap, and they make some network cards that are even cheaper than dirt (like $5.) If you took that out of the equasion, wouldn't you have a much larger range of choices both cheap and otherwise?
Anyway, I don't know about older boards, but I've had quite a lot of luck with my current MSI board. It supports overclocking to such an extent that they very nearly said overclocking was ok in the manual and ran quite stably when I did overclock it while my room was ultra-hot. The point I'm making about stability when overclocked is that if it can handle that, it can handle stock under considerably worse conditions.
