Mobo decision
Between this 2 boards what should i get.
1)gigabyte x38 DQ6
2)DFI LP LT x38 T2R
For now i will be running at stock speeds untill i learn how to OC safely P
Also if i get the Gigabyte will it fit a zalman 9700 ? cause it has that plate ont he back and not sure it might fit.
Since i alrdy have the zalamn i dont want to spend more money atm to replace it.
Probably the DFI.
You might also want to consider abit's IX38 QuadGT.
