Mobo/Case Fitment Question.
phorkz
It will fit just fine. The dimensions are length x width, where length is measured as the distance along the edge of the board on the same side as the rear I/O connectors (see image), and width is the distance along the top. (E)ATX has a standard length of 305mm (12in).
Thank You kind sir.
Motherboard Support
ATX, Micro ATX, Mini ITX,
E-ATX *(up to 275mm wide)
check the width but it should be fine.
I have the 350x and am pretty happy with it. hdd bay is a bit annoying but it works. what really chapped my ass about it is the price of another ssd caddy, its 1/3 of the case price in CAN.
