Mobo bad?
Obi_Kwiet
I'm fixing a friend's PC, which has an Athlon 2000+ retail HSF, and no case ventilation. :p I've asked about this before, but I've done some more tests tests and I'm pretty sure that the MoBo's gone. Ok, first, the part of the MoBo that cuts the CPU off if it gets hot (which is about ten seconds in this case (pun not intended) :p) still works. However, no matter what I do, I never get anything on the screen. I've swapped out the PSU, cleared the CMOS, swapped out RAM, and changed back and forth between the MoBo on board video and the PCI MX 440. There are no burn marks on the CPU, and both the CPU and the video card generate heat. I get no beeps of any kind from the MoBo at any time even though the speaker is connected. Now obviously I could figure this out in a second if I had another Socket A CPU or MoBo, but I don't. So, just so I don't waste any money, so I'm pretty safe in assuming that it's the MoBo right? Thanks.
Have you tried pulling the battery + clearing cmos? I just have been having problems with my an35n ultra mobo and still can't figure out what else to do but thats what people told me to do. I guess you can go buy a motherboard from a local frys or something and test it on that..and if it works I guess your mobo is dead =]
Yeah, I pulled the battery when I cleared the CMOS. I guess I'll go ahead and buy a new MoBo from New Egg. I really can't imagine it being anything else. I mean, it would beep if the CPU was gone.
Obi_Kwiet said:
Ok, I recently was asked to looked at one of my dad's friend's PCs. He said that he had "had motherboard replaced before" and that he "thought it went bad again." With no more info than that, I opened the case, first noting that it said PIII 866MHZ on the front. First, not only the motherboard, but the also the CPU had been replaced with some Athlon CPU, probably in the 1400+ - 2400+ range, using, of course, the retail HSF. I also noticed that the only fan in the case, which was only designed to cope with the heat of a PIII, had been removed. :p So I try to boot it up, and (surprise surprise) it stays on for ten seconds and turns off. I try to do it again, and I get the same thing. I remove the CPU, and turn it on, and it stays on. But no error beeps or anything on the screen at anytime. I'm 95% sure the CPU has been fried. It has a Biostar M7VIG Pro-D Motherboard, and a passive cooled Geforce4 MX video card. I tried plugging the monitor into both that and the motherboard's integrated video card. So, I'm about to order a new CPU, and just to make extra sure, I thought I'd check and see if you think it's anything else before I order a new one. I'm 15 and just doing a favor for a friend so it's not really a business or anything. Thanks.
That should be what your looking for. Unfortunately, there are no visible scorch marks on either the CPU or the MoBo at first glance. It did see a small brown mark on the south bridge, but that may have been something else. It didn't look like a burn, but I could be wrong.
