Its been along time since I posted on this board but everyone was very helpful last time I was here.
So here is my problem. I recently upgraded some of the components on my pc and have been having trouble since.
My new parts are as follows:
EVGA GeForce 9600GT
BIOSTAR P4M900M4
Crucial 2x2GB DDR2 667
All the other components are from my old machine so I know they work. The reason I went with this set up is because the motherboard allowed me to use an old processor and save some money. Yes I know bad idea.
The problem I have is that when playing games (WoW, TF2) my monitor will go black, then go into standby, and the sound will just loop. The only way to restart is with a hard reboot.
I have updated all the drives and even tried to roll back to some old ones with out any luck. Ive run memtest and done a stability test on the video card. Now all of these checked out and I only have problems gaming, not web surfing or watching movies/videos. I believe my problem may be that my video card is PCI-e version 2.0 or Gen 2 and the motherboard doesnt like that. On the Biostar website they state that NV8800 will not work because Its due to hardware support limitation to the Gen II PCI-E VGA card support from the chipset. While thats not the same video card I have I believe thats my problem.
Has anyone else run into similar problems or any ideas on how I might fix it?
As I dont expect this to be any easy fix, Im planning on just upgrading to another motherboard and new processor. Money is of course an object but I still would like a good solid board with a decent processor as close to or under $200. Any recommendations on a good mobo that I can run the same memory on(667) and my use my new video card. I ask because Im not sure about running different memory on different motherboards, i.e. the motherboard requires 800 and I use 667, will this work or will I need to OC? And the fact that the motherboards Ive looked at on newegg dont say PCI-e 2.0 or anything like that.
Any help would be great. Thanks
EVGA GeForce 9600GT
BIOSTAR P4M900M4
