Mobility 9200 Vista Problem
cooter
System:
Sony Vaio VGN-S150 (I love this little laptop)
1.6 GHZ Dothan
ATI Mobility 9200
1 GB DDR400 Micro SO DIMMS
80 GB 7,200 RPM HD
First thing I want to make clear is that I have tried Sony support and they, as suspected are completely washing their hands of anything with my laptop and vista.
The problem I have is that the graphics drivers install fine (the default vista ones) however I do not have the choice to choose my primary display. At work (this is my work laptop) I run a 19" LCD and the widescreen monitor as a dual monitor configuration. In XP i was able to make the 19" LCD my primary monitor which is something I want for the use of LiveMeeting and so-on. When I go to the Display properties to check the "This is my Main Monitor" box the box is grayed out.
Does anyone know of a registry hack or a way change the primary display with this situation?
Thanks
I seen that, I was wondering if there is any way to edit an .ini file to add my card.
