Hello all,
Sorry for the wall of text... I have scoured the internet for hours seeking an answer to this question and while I never found the answer I did find this site which seems to have the most hardware knowledgable people around! Maybe you can help me.
I have an Alienware M15x laptop with a ATI Mobility Radeon 5850 graphics card.
I see that this card supports eyefinity (from ATI's website) The M15x has two video outputs a standard VGA and a Display Port. I guess, therefor, that I could run two additional screens and my laptop screen for a total of 3.
But the laptop screen is only 15". Ideally I'd like to run 3x24" monitors (i.e. shut off the laptop screen and run 3 external monitors). Is there anyway I can do this on the M15x? My searches have turned up the phrase "daisy chaining" in relation to display port. This seems to suggest the possibility of running multiple monitors off a singe display port output... Is this possible?
I also see that dell sell this Multi-Monitor Hub Adaptor. Reading the description it seems that it allows 3 monitors from a single display port. Des anyone know if this solution would work with eyefinity to produce the desired effect?
Any help massively appreciated! I see that HP produce a laptop that has the same card and runs eyefinity... though that laptop has an additional HDMI out... I really hope its possible on the M15x too as I can't afford to build a whole new system just for this feature
