DGMurdockIII
- Jan 16, 2015
Can we get a mobile formated forum or support for taptalk
So what exactly is your issue with how it works now? What is your problem?it not mobile formated if you can still zoom in that not formated for mobile it it is close but not aslo make sure your you have this enabled https://xenforo.com/community/threads/responsive-design.50888/ it the defult so moble is supported
or use this addon https://xenforo.com/community/resources/soft-responsive.1080/
That is the way our forum format works. Should you not want to zoom, then do not use it.then why can i still zoom in mobile pages are not supposed to allow for zooming in they are supposed to be formated for the mobile phone im on android BTW
I think you would be much better off managing your own forum rather than mine. Thanks for your input.but dont you want to get %100 or at least %90 in all categorizes
