Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Does anyone know of a good vendor for a mobile (on casters) 4-post cabinet (in the 12U to 14U range - something that'd go under or next to my desk). I'm getting to the point where I need to start rackmounting my lab hardware.
Look for racks used by touring musicians, you can find good mobile ones for a few hundred. Bass guitarists especially use them, with pre/power amps, effects, compressors.. oh my!
Build it then. Order rack rails and build the frame out of metal square tubing. Get someone to weld it if you cannot or don't want to. Then simply attatch plywood to the sides and add castors. Job done.
