Hi just bought a refurb motherboard (http://us.shuttle.com/specs_access.asp?pro_id=498) and was hoping to put either: http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-440&depa=0 or
http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-400&depa=0
I have check the CPU support here:
http://www.shuttle.com/hq/support/faq/supportlist2.asp?model=AK38/N
Quote Shuttle:
" 1. CPU internal core bus speed runs at 200/266/333MHz. supported. 2. *AMD Athlon XP with .13 micron process technology is supported. 3. **AMD Athlon XP with .13 micron (Barton core) process technology is"
I'm concerned by the 35 Watt and 45 Watt spec on the chips. I have already kill muliple CPU due to bad luck and my own stupidy so I want to make sure before trying again. Well that it hope you all can help out.
Quote Shuttle:
